All,
We are currently using WF3/m240 with PDMLink 9.1/m40.
We are working on upgrade to WF5/m90. In our testing, WF5 is slower
interacting with PDMLink versus WF3 in just about everything we're measuring.
We are using IE8 as the browser, as we are having issues getting the Mozilla/Gecko
browser to work (it disappears).
We are working on reviewing the config, clientregistry and server side settings,
but am wondering if this is something that is a known issue with WF5 and if I'm
fighting a losing battle.
Thanks!
Tom Hogan
In Reply to Tom Hogan:
All,
interacting with PDMLink versus WF3 in just about everything we're measuring.We are using IE8 as the browser, as we are having issues getting the Mozilla/Gecko
Thanks!
Tom Hogan
We do not have a comparison between WF3 and WF5 but definitely experienced quite a significant loss of performance between WF4 and WF5, especially memory consumption.
Which OS are you using? Win 7 64-bit should improve the performance. We're still struggling with XP 32-bit.
Mozilla did not work, have you tried config optionwindows_browser_typeie_in_sep_process
This TPI have recomended tuning options for PDMLink and IE8https://www.ptc.com/appserver/cs/view/solution.jsp?n=141292
These are settings recommended from PTC to avoid conflicts in PDMLink.
relat_marks_obj_modified no
retrieve_data_sharing_ref_parts no
bump_revnum_on_retr_regen no
freeze_failed_assy_comp no
new_asm_regen_revnums no
regen_read_only_insts no
regenerate_read_only_objects no
save_objects changed
mass_property_calculate by_request
mass_prop_update_force_change no
mark_insts_modified_by_mp_calc changed
create_drawing_dims_only yes
save_modified_draw_models_only yes
open_simplified_rep_by_default no
save_implicitly_verified_insts no
save_instance_accelerator none
retrieve_instance_dependencies instance_deps_only
