Hi everybody
Many years ago as an applcation engineer for PTC I was advised that youshould not install Pro/ENGINEER into the Program Fles folder on a PC - the reason being Pro/ENGINEER did not like the space between Program and Files in the folder title. Consequently every Pro/ENGINEER installation I have ever carried out has always been into a folder like
C:\PTC\proewildfire3
I'm just curious to know ifis this still relevant advice. Does Pro/ENGINEER still get upset by the space? Did it ever get upset by the space?
Neal
Yes, it is still relevant to stay away from spaces and special characters (such as punctuation.Although PTC claims that they meet Microsoft requirements for such, it is not 100%. Every few months, someone posts a problem related to this. We had one less than a month ago in which it was found that Windchill could not properly deal with the java path if it contained special characters.
Gerry
From what I have been able to tell for working with 2001, WF3, WF4, and WF5, the problem with spaces in the folder path is no long an issue for Pro/ENGINEER. Other PTC products (Intralink, Windchill, etc) still have problems on occasion and if they link up with Pro/E, then you may see that some options do not work.
The one example I can think of right now is if you have Pro/E installed to a directory with a space in it (ie, c:\ptc\wildfire 4.0\), then Intralink 3.4 will be unable to run the Import/Export command.
In Reply to Neal Hanratty:
Hi everybody
Neal
Even if it seems to work most of the time, using spaces or special characters may have unexpected side effects.
Using ä (a-umlaut) in a workspace name f.i. kept ProE from loading drawing formats...
Just got through with an install of WF4.0 with Intralink 3.4 (M062). Space in the folder name for the install of WF4.0 ... By PTC install CD default caused me grief!! Linked session of Pro-E and Ilink kept giving "loadinpro" error and loss of viewed data in the workspace window. The initial setup install for WF4.0 created a folder named "proeWildfire 4.0" the fix was to have it install to "proeWildfire_4.0" or rename theexisting folder and re-run setup. That fixed the problem.
Dave
Hi everybody
Neal
