Pro/Toolkit Visual Studio 2010 configuration
vpapa
Hi guys,
I'm trying to implement a template for visual studio 2010
for working with Pro / Intralink C + + for CREO 2.0 x64.
I have some linker errors, not that any of you could share
a project that is already configured?
Thank you very much,
Vincenzo
Here are some of the important things to check while configuring ProToolkit project in VS -
  • Decide application type Synchronous OR Asynchronous.
  • Depending on application type add libraries under Linker->Input->Additional Dependencies.
  • Set code generation flagas /MD.
  • Also check /clr option.
You can also refer "Creo Parametric TOOLKIT - Library Types" in tkuse.pdf for more detailed information.
Libraries we add in project is one of the main cause of linker errors in ProToolkit project.
shamkumar
(To:vpapa)
Add below mentioned environment variable.
Variable Name :- CREO_INSTALL_PATH
Variable Path :- C:\Program Files\PTC\Creo 2.0\Common Files\M030
and unzip attached folder and run the project
NOTE:- Rename "otk_install.zipa" with "otk_install.zip"
Shamkumar Rajput | Member of Technical Staff
*Centre for Computational Technologies - CCTech*
1 Akshay Residancy | 50 Anand Park | Aundh | Pune | 411007 | India
Ph: +91 20 40098381/82 | M: +91-8446272928 | www.cctech.co.in
*CCTech – "Simulation is The Future"*
