It seems this is a well-known issue. While exporting a drawing to DWG, it ¨becomes¨ smaller. I already tried changing these config.pro options, and nothing happens.
Creo 4.0 to Autocad LT 2014
DWG_EXPORT_FORMAT | 2010 |
| DXF_OUT_DRAWING_SCALE | YES |
| DXF_OUT_SCALE_VIEWS | NO |
I already attached some things.
Thank you!
I have the following lines in my config.pro and I get correctly scaled (1:1) dxf & dwg files.
dwg_export_format 2000
dxf_export_format 2000
dxf_out_comments NO
dxf_out_drawing_scale no
dxf_out_scale_views yes
dxf_out_sep_dim_w_breaks NO
Walt Weiss
Solution: Change drawing units to mm and export DWG.
MH
