Productview - parts not showing up
JWayman
We are having trouble with PV9.1.
I open an assembly in Pro/E (WF2) and it displays as expected.
I do 'File, Backup' and save the assembly to my hard disc. I open that from
Pro/E and it displays as aexpected.
I open the same assembly using PV and, of the 7 components, only two show
up.
Do you have any idea why this should be?
The parts were all created on the same machine, using the same start part
and the same config.pro, as far as I can tell.
I'm baffled now.
Cheers,
John Wayman, C.Eng, FIED
Senior Mechanical Engineer
This email, including any attachment, is a confidential communication
intended solely for the use of the individual or entity to whom it is
addressed. It contains information which is private and may be proprietary
or covered by legal professional privilege. If you have received this email
in error, please notify the sender upon receipt, and immediately delete it
from your system.
Anything contained in this email that is not connected with the businesses
of this company is neither endorsed by nor is the liability of this company.
Whilst we have taken reasonable precautions to ensure that any attachment to
this email has been swept for viruses, we cannot accept liability for any
damage sustained as a result of software viruses, and would advise that you
carry out your own virus checks before opening any attachment.
JWayman
(To:JWayman)
I have also just noticed that the progress bar at the top of the screen
never makes it all the way across and the little curly-wurly string of dots
just keeps on going round...
John
   _____
