Gurus,
When inserting a hole I select the following: Hole Tool, Standard Hole,
remove tapping, counter bore, up to surface. Then modify the size in the
shape gui. Done. Later when I try to modify the hole dynamically from
the model, I always get a "read only" error when picking the smaller
diameter. I have the config option set [hole_diameter_override yes].
What else can a try?
Eric
Wildfire 4.0 Datecode m050
Windchill 9.0 Datecode m030
