Rename the model in the workspace through secondary development
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
When the standard function server is online, you can only rename the model or modify the name of the model in memory through "File-Rename" in the workspace. I hope that through secondary development, I can make a tool that can quickly rename the models in the workspace (automatically perform the "file-rename" operation). There is no relevant interface found in the Toolkit help file, and I don't know if there is a way to realize this function.
Translated from Simplified Chinese to English using google translate on 17th April 2023 at 11:42am IST. Translated by vnambooheri
Subject: 通过二次开发在工作区中重命名模型
Body: I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
标准功能服务器在线时只能在工作区通过“文件-重命名”对模型重命名或者修改修改内存中模型的名称。希望通过二次开发,做一个工具,能够快速为工作区中的模型进行重命名,(自动执行“文件-重命名”的操作)。在Toolkit帮助文件中没有找到相关的接口,不知道有没有办法能够实现该功能。
