Renaming a part is closing related drawing
hkatgert
8-Gravel
When we switched from Creo 2.0 M060 to Creo2.0 M110 we faced that renaming a part is closing the related drawing.
Starting Creo without config.pro is solving the problem so some setting is causing this behavior.
Who can support me?
To reproduce:
  1. Open drawing + model
  2. Activate model
  3. Rename model
  4. Drawing window cleaned which should stay open.
Hansov,
start with empty config.pro and add options little by little. This way you can find the problematic option.
Note: You have to upload you config.pro, if you expect an assitance of user community.
Martin Hanak
Martin Hanák
Hansov,
Take a look at config.pro option "rename_drawings_with_object". If that is not the case, Martin's comment is the best approach.
