Renaming a part is closing related drawing
hkatgert
7-Bedrock
When we switched from Creo 2.0 M060 to Creo2.0 M110 we faced that renaming a part is closing the related drawing.
Starting Creo without config.pro is solving the problem so some setting is causing this behavior.
Who can support me?
To reproduce:
  1. Open drawing + model
  2. Activate model
  3. Rename model
  4. Drawing window cleaned which should stay open.
2 REPLIES 2
Hansov,
start with empty config.pro and add options little by little. This way you can find the problematic option.
Note: You have to upload you config.pro, if you expect an assitance of user community.
Martin Hanak
Martin Hanák
Hansov,
Take a look at config.pro option "rename_drawings_with_object". If that is not the case, Martin's comment is the best approach.
