Run Batch file after Creo exit
dgschaefer
I'd like to run a batch file after Creo is exited to copy the user's *.ui file from the local cache to the server, only if the local file is newer.  Is it possible to have a batch file run at exit?
LinkedIn
0 REPLIES 0
