SUMMARY: help with mass props reporting
lylebeidler
In regards to simply using the config options
mass_property_calculate automatic
save_objects changed
It seems I need to retract my earlier statement that "this config setting
does not seem to be a good choice in conjunction with Intralink."
The issue I was having stems from family tables.
Let me start from the beginning. Several users instructed me to simply move
my relation POUNDS = PRO_MP_MASS to the "Post Regeneration" section of the
Relations, and use the above config options, and that would solve all my
problems. I had tested this, and found that this resulted in oodles of
modified parts. I was advised, "It'll only happen once - check those parts
in and they'll never be modified again after subsequent mass prop
calculations." I tested this, and found it to be untrue - I was STILL
getting oodles of modified parts. That's when I made the statement above.
HOWEVER, I've further tested it, and discovered that the issue stems from
Family Tables. Specifically, I needed to add the POUNDS parameter to the
family table for any part which uses the POUNDS = PRO_MP_MASS relation.
Once I did that, it appears to fix the issue.
Thanks to all that helped (and that prompted me to keep investigating!)
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
