New user to Creo here, switched over from Solidworks, loving the program so far.
My question is has anyone else had an issue with the Extend command? I use it to extend the edge of the part to complete the bend line but every once in a while after it has worked the part says the function failed so then the only way to fix it is to completely get out of the program after saving everything and open it again and regenerate, which fixes the problem.
Has anyone else had this issue or is it a common quirk in Creo?
Thanks for the help!
