When I Run a Analysis the analysis Results Fails with this message in Checkpoint tab.
"The License to run the Engine is not available"
Please help me with this Issue.
Hello Kishan,
missing license error can have a lot of causes. The most obvious is that you don't have the license required or that all those licenses are used already by someone else.
Have you followed the advice in the error message to contact Technical Support?
Maybe you can let us know, what caused the error.
Gunter
