HI,
I want to update the date code in Creo parametric 2.0, currently I am using M030 & I was told M050 is a stable date code,
But currently M110 is available for download, Can anyone suggest what is stable date code to download?
PS: My client is using M090.
Pradeep
i would prefer M100 over M090 and M110.
But, Will it be a problem to open a model saved in M100 in M090? Will it give any issues?
Same, M100.
All build date codes of Creo 2 (or any version) are file compatable. You can open any file saved in any build of Creo2 in any build, upwrds or dwonwards.
