I am using Creo Parametric Release 8.0 and Datecode8.0.1.0
When I print a postscript file, Adobe Distiller leaves off ASME fonts from the drawing like diameter and degree. What font do I need installed?
I guess you can test ...\Creo 8.0.1.0\Common Files\text\fonts\symbol_asme.ttf file.
I found a config.pro option that ended up working:
ttf_handling_for_plot_files stroke all fonts
