Help!
I'm running Creo 2.0 date code M230. I'm trying to save a symbol that I've successfully defined, but when I try to write it to disk, I get an "invalid directory name".
Config.pro is set like so:
pro_symbol_dir C:\home\LWL\M7082\Symbols
User permissions are fine, no problems saving other files (drw, .asm, .prt, etc.)
Anyone have an idea or two? I'm stumped.
Ray Aviles
Manufacturing Engineer II
Dear Ray,
have you fixed your problem?
Today I'm figthing against the same problem with Creo 4 M090.
Dear ggallo_ceme,
I don't know that this is a 'fix', but it works for me. Don't type anything; just press ENTER. The symbol will be saved to the specified directory in your config.pro, for example:
pro_symbol_dir C:\program files\Creo4\symbols
Hope this helps,
Ray Aviles
