The selected functionality requires CFD Analysis license
KJ_9947772
7-Bedrock
I am using Creo Parametric Release 4.0 and DatecodeM040
not able to use Flow analysis functionality
Here are the errors that I faced
@VladimirN, thanks for your reply but that solution did not work for me.
So, I added the feature name "PROE_DesignPrmP " in the "parametric.psf" file and it worked. As PROE_DesignPrmP does include option module "CFD_Basic" or "CFD Advance" licenses.
2 REPLIES 2
Article - "About Creo Flow Analysis packages introduction in Creo Parametric": https://www.ptc.com/en/support/article/CS277387
