Just moved from Wildfire 4 to Creo 2 last week and I'm looking for the viewing command in Creo 2that enables me to toggle back and forth from viewing cables as either "Thick" or "Thin" when in a model (i.e. not in a drawing view).
There was such a toolbar button in WF4 but all I can find in Creo 2 to control Thick/Think cables is a config.pro setting.
Has anybody found a ribbon command to toggle between Thick/Thin cable display?
TIA.
Additional Info: To create a short-term quick fix, I have created a couple mapkeys to toggle between Thick and Think cables. The mapkeys are a recording of going to File>Options>Entity Display and toggling the cable display there.
