Toolkit Asynchronous Application Configuration
PARTHIBAN_K
I am getting below mentioned error when trying  to create Toolkit Asynchronous example.
error LNK2019: unresolved external symbol_ProEngineerStart referenced in function_main()
I have used example file provided in toolkit installation folder → simple_async.
Anyone can help to configure t for Toolkit Asynchronous application
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
The Problem is Solved,
I missed pt_asynchronous.lib in the Linker
Parthiban Kannan
6 REPLIES 6
Are you using their 'make_simple_async' makefile?
What tool are you using for the compilation and for which Creo version?
Yes Tomas,
I am using make_simple_async
Creo Version 2.0
Visual Studio V2010
Parthiban Kannan
Ok, that's correct. Could you please post the whole output of the compilation? Have you made any change in the makefile?
Hi Tomas ,
I have added additional includes & now the previous problem solved but new issues created.
simple_async.cpp contains below error symbols.
Error1error LNK2019: unresolved external symbol ProTestCallReport referenced in function mainC:\TOOLKIT DEVELOPMENT\SIMPLE ASYNC\SIMPLE ASYNC\DFT\make_install\simple_async.objSimpleAsync
Error2error LNK2019: unresolved external symbol user_initialize referenced in function user_initialize_plusC:\TOOLKIT DEVELOPMENT\SIMPLE ASYNC\SIMPLE ASYNC\DFT\make_install\protk_dllmd.lib(pdp_pdevtk.obj)SimpleAsync
MAKE FILE :
# File Name
MAKEFILENAME = make_SimpleAsync
# Machine Type
PRO_MACHINE_TYPE = x86e_win64
# Executable names
EXE = SimpleAsync.exe
EXE_DLL = SimpleAsync.dll
# Pro/Toolkit Source & Machine Loadpoint  (EXTERNAL USE - DEFAULT)
PROTOOL_SRC = $(PROE_INSTALL_PATH)\protoolkit
PROTOOL_SYS = $(PROTOOL_SRC)/$(PRO_MACHINE_TYPE)
# Pro/Toolkit Source & Machine Loadpoint  (PTC INTERNAL USE)
#PROTOOL_SRC = $(PTCSRC)/protoolkit
#PROTOOL_SYS = $(PTCSYS)
# Include File Paths
INCS = -I. -I$(PROTOOL_SRC)/protk_appls/includes -I$(PROTOOL_SRC)/includes
# Compiler Flags
CC = cl
MACH = -DPRO_MACHINE=36 -DPRO_OS=4
CCFLAGS = -c -GS -fp:precise -D_WSTDIO_DEFINED
CFLAGS = $(CCFLAGS) $(INCS) $(MACH)
# Libraries
PTCLIBS = $(PROTOOL_SYS)/obj/protoolkit.lib
PTCLIBS_DLL = $(PROTOOL_SYS)/obj/protk_dll.lib
LIBS = libcmt.lib kernel32.lib user32.lib wsock32.lib advapi32.lib mpr.lib winspool.lib netapi32.lib psapi.lib gdi32.lib shell32.lib comdlg32.lib ole32.lib ws2_32.lib
# Object files
OBJS = simple_async.obj
# Linker
LINK = link
$(EXE) :  $(OBJS) $(PTCLIBS)
  @echo Start at `date`
  @echo PROTOOL_SRC = $(PROTOOL_SRC)
        @echo PROTOOL_SYS = $(PROTOOL_SYS)
#Executable applications compiled using WinMain() instead of main() should set the subsystem to windows instead of console.
  $(LINK) /subsystem:console -out:$(EXE) /debug:none /machine:amd64 @<<longline.list
$(OBJS) $(PTCLIBS) $(LIBS)
  @echo Finished at `date`
  del $(OBJS)
# Dll target
dll: $(EXE_DLL)
$(EXE_DLL) :  $(OBJS) $(PTCLIBS_DLL)
  $(LINK) /subsystem:console -out:$(EXE_DLL) /debug:none /machine:amd64 /dll @<<longline.list
$(OBJS) $(PTCLIBS_DLL) $(LIBS)
  del $(OBJS)
# OBJECT DEPENDENCIES
PATH_SOURCE = C:\TOOLKI~1\SIMPLE~1\SIMPLE~1\DFT\MAKE_I~1
simple_async.obj: $(PATH_SOURCE)/simple_async.c
  $(CC) $(CFLAGS) $(PATH_SOURCE)/simple_async.c
PROTK_INST = $(PROTOOL_SRC)/protk_appls/pt_install_test/pt_install_src
PROTK_UTILS = $(PROTOOL_SRC)/protk_appls/pt_examples/pt_utils
TestError.obj: $(PROTK_UTILS)/TestError.c
  $(CC) $(CFLAGS) $(PROTK_UTILS)/TestError.c
UtilString.obj: $(PROTK_UTILS)/UtilString.c
  $(CC) $(CFLAGS) $(PROTK_UTILS)/UtilString.c
clean :
  del $(OBJS)
  del $(EXE)
  nmake -f $(MAKEFILENAME)
clean_dll :
  del $(OBJS)
  del $(EXE_DLL)
  nmake -f $(MAKEFILENAME) dll
Parthiban Kannan
You have to check the linker problems - maybe some path is not set correctly or some file is missing...
I just simply created following .bat file for compilation in the make files folder (creoinstaldir)/protoolkit/x86e_win64/obj
call "C:\Program Files\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" x86_amd64
"C:\Program Files\Microsoft Visual Studio 10.0\VC\bin\nmake" /f make_simple_async
pause
and when I run it, it is compiled without problems. I have still 32 bit machine...
This is the output from the compilation I expected you will send me:
Setting environment for using Microsoft Visual Studio 2010 x64 cross tools.
Microsoft (R) Program Maintenance Utility Version 10.00.30319.01
Copyright (C) Microsoft Corporation.  All rights reserved.
        cl -c -GS -fp:precise -D_WSTDIO_DEFINED  -I.  -I../../../protoolkit/prot
k_appls/includes -I../../../protoolkit/includes  -I../../../protoolkit/includes
-I../../../protoolkit/protk_appls//includes -DPRO_MACHINE=36 -DPRO_OS=4 ../../.
./protoolkit/protk_appls//pt_simple_async/pt_sasync_src/pt_sasync_src.c
Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
pt_sasync_src.c
./protoolkit/protk_appls/pt_examples/pt_utils/pt_utils.c
pt_utils.c
Start at `date`
PROTOOL_SRC = ../../../protoolkit
PROTOOL_SYS = ../../../protoolkit/x86e_win64
        link -out:pt_simple_async.exe /subsystem:console /debug:none /machine:am
d64 pt_sasync_src.obj pt_utils.obj ../../../protoolkit/x86e_win64/obj/protoolkit
.lib libcmt.lib kernel32.lib user32.lib wsock32.lib advapi32.lib mpr.lib winspoo
.lib
Microsoft (R) Incremental Linker Version 10.00.40219.01
   Creating library pt_simple_async.lib and object pt_simple_async.exp
Finished at `date`
        del pt_sasync_src.obj pt_utils.obj
Press any key to continue . . .
Parthiban Kannan
