UDP files for custom tool parameters - Solid Tool
HI folks!
I´m trying to use .xml UDP files along with the config.pro option mfg_custom_tool_param_file but although my UDP file seems to be correct, the new "User Defined" tab does not appear in the tool manager. I checked if I have the parameters properly set at the solid tool model and it´s there too...
Using WF3 M230...
Any ideas or examples you could share?
Thank you
Daniel
Using WF3 M230...
Thank you
Daniel
