Sep 15, 2016 3:28 AM UTC
VBA API IN CREO
Hello ,
I am new to Creo, I am expert in solidworks vba API, Now i want to learn creo API.
Can any one tell me how i can open vba environment in creo, is there need to purchase any special license.
Thanks in advance
Sep 16, 2016 5:38 AM UTC
Hello Ganesh,
  1. Like SolidWorks, CREO doesn't have own VB Environment, But Creo having VB Libraries with Limited functions to access CREO tools. It is free only. VB API only works with Asynchronously in CREO. So need to develop your external environment through MS Office VBA or Visual Studio VB.NET.
  2. To work Synchronously with CREO, you need to use CREO Toolkit (C/C++) or J-Link (Java). which also does not contains own Environment. You can access maximum functionality in CREO with these tools. Also you can use ProWebLink for Web Environment.
  3. CREO Toolkit required Costlier License. J-Link is Free License.
  4. Access the VB API User Guide, Sample files from CREO Installation Folder. Path looks like this C:\PTC\Creo2-amd64-M120\Creo 2.0\Common Files\M120\vbapi
2-Explorer
Sep 16, 2016 2:58 AM UTC
There is no VBA environment in Creo. The Creo VB API is accessible from other applications, including VBA. I b believe there is no VBA-specific interface.
This may be of use: VB-API and Excel VBA
Hello Ganesh,
gdevkhile1-VisitorAuthor
Mar 10, 2017 10:52 AM UTC
Thank you pathiban kannan,
How do i connect MS Office VBA to  creo vb libraries to access creo command.
Thanks in advance
2-Explorer
Mar 10, 2017 6:45 PM UTC
In the VBA code editor - look for Tools -> References. Chose the Creo libraries.
