Maybe the instructions from http://stackoverflow.com/questions/1248171/how-to-run-a-batch-file-from-a-network-share-in-vista-without-the-warning-dialogwill help you:
1. Open Internet Explorer's Internet Options
2. Click the Security tab
3. Select the "Local Intranet" zone
4. Click the "Sites" Button
5. Click the "Advanced" Button
6. Add the network name of the computer you're running the batch from as follows:
This will cause the specified computer to count into the "Local intranet" zone which won't trigger the warning as you have chosen to trust it.
Best regards, Domenic
In Reply to Domenic Laritz:
6. Add the network name of the computer you're running the batch from as follows:This will cause the specified computer to count into the "Local intranet" zone which won't trigger the warning as you have chosen to trust it.
This definately worked for me on windows 7. Was getting similar error with al CAd apps run from a server. Adding the server to the trusted list stopped the message.
Simon Lucas
