Wildfire 4.0
ptc-1044084
Wildfire 4.0
Just started to use Wf 4.0 and for some reason the windows come up only half the screen starting from the top. it will not extend to the bottom. I can drag it down, but each additional opened window will com in half way again. I can't find a config option that controls this? any ideas would be appreciated.
Mike, We use the following config option that I think does what you are looking for: windows_scale 1 with a value of 1. This option states: Scales Pro/Engineer windows with a given coefficient. A value of 0.85 is usually adequate to allow dynamic menus to display to the right of the Pro/Engineer window. Dennis
Dennis, Thanks for the reply. Unfortunately, that was the one thing i did figure out and it still doesn't seem to work. I just thought that 4.0 might have a different "secret" option... Thanks again, I'll keep trying
I don't know if this config option helps in WF4 or if it has no effect. open_window_maximized yes There is also a setting under Customise Screen - Options that might have the same effect.
