Wildfire2 on Win7 x64 ???
gbon
Hi alls,
I have to work on Wildfire2.
I'm trying to install it on my Windows7 x64 notebook unfortunately.
Can someone tell me if it's possible or not ?
So, should I install Win7 x32, Vista, XP, Win 3.11. 😉
Thanks for any advices,
GB
TomU
(To:gbon)
It will run fine with a couple of tweaks. You will need to install it on a 32 bit machine and then manually copy it the 64 bit machine. Then you will need to tweak any .bat file in the bin directory (that you actually use) to not look for processor type. Just change them enough so they think you are running a 32 bit processor. I can help with the specifics if you need it.
Tom U.
