Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Hi, I have just installed Pro/E WF4 on Windows 7. It starts up ok, but the performance is terrible to the point its unusable. It's as if no graphic drivers are installed or something? But they are up to date? Do I need to install an older set of Vista drivers or something? Anyone else had the same problem? Thanks
