I am using Creo Parametric Release N/A and DatecodeN/A
can you help me to change .CRC files location path?
I know TRAIL files and else can change the location.
I try to find the option command. But I can't.
I will look forward to your response.
As far as I know .crc files have been and always will be written to the current working directory. Makes sense, since they pertain to the files in that directory.
A more important question that should be addressed is why they are being created? A .crc or circular reference file is indicating a model has an error in logic in the definition of one or more features. They are only created when there is a problem. I'd be more concerned with fixing things so they are not created, rather than being concerned with where they are written.
