Hi all
I had seen a nice idea on Wensday night, and I am trying to duplicate it, but I am unsure just how to do it.
Basically it is adding a note with a parameter to the corner of the work space within an assembly and part work space, kind of like a drawing table on a drawing, so that it is fixed regaurdless if you zoom in or out.
Now I know how to add a Note annotation with a parameter, and I can place it on the work space within an assembly, but how can I fix it to the corner and fix the size regaurdless of the zoom.
it was in a demostration on setting up the config.pro file, is there a setting I need to add?
Thank you
Peter
Set the active annotation plane to the screen (Flat To Screen). Now place the annotation "note" on the screen and it will stay put.
This is Creo 1.0 or 2.0... not sure what version you are working with.
Thanks for the reply, I now have it set up
Peter
