how to change cache folder creo 2.0?
casotech
I have to change the folder where is saved the cache by default, how do I do?
What you are looking for is actually an environmental variable in Windows. The variable is PTC_WF_ROOT. Where I work, we have a batch file that runs before Creo launches that sets this variable with the command:
set PTC_WF_ROOT <location>
where <location> is the path to where you want your cache to be stored.
The old default location for this was: /Users/<username>/AppData/Roaming/PTC/ProENGINEER/Wildfire/.wf (or just %appdata%/PTC/ProENGINEER/Wildfire/.wf).
4 REPLIES 4
You can copy me the batch file?
While we can send you launch scripts, they are personalized to the needs.
I suggest you look here
ProE Launch Script.docx
This will give you all you need to know and more.
davehaigh
(To:casotech)
