how to configure a context sensitve help globally
AwadheshNaik
7-Bedrock
Hi ,
I would like to know if the context sensitive help, can be configured globally.
To elaborate, I want to install the proe help (%proe base dir%\html\proe_help) in single location in some remote server. All the users would have access to it. Off course all the users will have their local proe installation. Whenver they click the "What is this ?" icon in Proe, and then click on any icon, the information will be picked from that server location.
Currently context sensitive help ("What is this ?" in Proe) works for my local installation.
Regards
Awadhesh
if you are using ProE WF5, then read Creo Elements/Pro 5.0 Installation and Administration Guide - M080
https://www.ptc.com/view?im_dbkey=123932
https://www.ptc.com/appserver/cs/doc/refdoc.jsp
See Chapter 6 Installing and Using Creo Elements/Help.
Martin Hanak
Martin Hanák
2 REPLIES 2
Martin Hanak
Martin Hanák
Thanks... Hi Martin.. I refered the PDF for WF5 and its working. Can you give me some inputs on WF3 context sensitive help. I refered the PDF but it does not provide any web_deploy.bat file. I will post if I get any help. But before that any suggestion is welcome.
