Another new company config to wrap my head around... I'm looking for the config setting to allow hide/unhide layer settings in parts to show up in assemblies. Currently, if I turn all layers off in my assembly, select andopen a part from the assembly,turn a specific layer on andthen go back into theassembly, the part layer I turned on does NOT show. I WOULD like it to show, and have had this behavior in past configurations. I know I can turn the layer on right from the assembly, but if you have a large assembly and "undisciplined" layer usage, this can be inconvenient, where as simply opening the part, and dealing with only it's layers can be simpler. I could not find the answer in the forums...
thanks in advance...
Paul.
