Yes, you can install/configure Creo with license server information and lock license file. When installaing, under license identification, point license file (lock) and server name with port.
e.g. 7788@Server;License file path and name
if you want to have two options (LOCKED, from_SERVER) when starting Creo, then you have to define two startup commands (psf files in Parametric\bin directory). If you need more information about editing psf files, please let me know.
