This is my first post! I have a quick question:
I tried setting mark_approximate_dims to 'no', in my config.pro, but the tildas are still showing in my dimensions that use fractions. I deleted all of my config options that have it set to yes (config.sup), but it still isn't changing. I'm using Creo Elements/Pro.
Is this option broken or am I missing something?
Thanks for your help!
Joe
Did you restart your Creo after you changed the config option?
that worked!
Thanks!
Is there a rule-of-thumb for which options need a restart and which don't? This is the first one I've encountered that needed a restart.
I don't know what determines which options require a restart. If I change an option and I don't notice an immediate change the first thing I do is restart Creo.
You should also usually just have to open the config.pro file.
