I am using Creo Parametric Release 11.0 and Datecode11.0.0.0
Modelcheck is not running properly. i have the files setup. (config_init.mc... and others). i have also enabled modelcheck in the config edit as well that the Modelcheck_dir. I have also enable show_reports. (see attached pic). When I run Modelcheck interactive, it completes the process but does not display the modelcheck screen.
I
