ptc creo parametric is to slow while using virtual box
jfrancomontero
Hy there, im running parametric ptc on my mac with virtual box.
But there is one issue: It's running very very slow.
My computer is almost new so I do not thing that it depends of the graphic card.
Is there anything to with?
Thanks in advance
2 REPLIES 2
Creo Parametric normally uses hardware accelerated OpenGL for graphics. If you run it in a virtual box - I assume a type of advanced Windows emulator - I would be surprised if it didn't switch to the slower WIN32_GDI graphics mode. And then it is not using the modern graphics capabilities at all, but basically 2D graphic routines with everything computed by the CPU.
Open File > Help > System Information and scroll down to Machine Information to check.
And? Have you succeeded?
I've the same problem!
Is there any chance to run creo on a virtual machine?
Has anyone experience with vbox, vmware?
Greetings,
Holger
