This has been a hidden config option for a while. Do you guys remember what the values were?
Also, is there a second gatekeeper config option that unlocks this for use? I have tried a couple things and it's still grayed out.
Dean,
I think default value for this is yes and if I am not wrong it will select the parts in assembly by window selection after setting smart filter to parts.
Dean,
