saving individual drawing package from assembly drawing package
rbhatta
Hi all,
I want to save individual drawing sheets from a single drawing file of 100s of sheets (1 drawing file for each sheet). I want it as native drw file. Can anyone point me how to do that as I haven't been able to find a simple way for this.
Thank you
Ravi Bhatta
rcrerar
7-Bedrock
(To:rbhatta)
Hi, You should be able to save the drawing 100 times to new numbers and simply delete the sheets that you don't want if the 100 sheet drawing already exists. if you save the drawing it will not create additional models. Don't do it the other way, saving model will create new drawing and models and that will be a headache for you.
rbhatta
(To:rcrerar)
Thank you Roy for the reply. I was going through the same process and it seems I have total around 400 sheets and saving each and deleting the sheets out of each is taking a lot of time for me. If there is no other quick way, seems I have to stay with this then.
Thank you
Ravi
