spacemouse
rjeli
spacemouse
I cannot use a 3DConnexion space mouse with Wildfire 5.0 on Windows 7.  If I install the Space mouse then I cannot run Wildfire.  I contacted 3DConnexion and told me most likely, the problem I'm experiencing with thier driver software is related to the operating system. Microsoft developed a tool which is designed to fix such errors. Please find this tool at:
https://support.microsoft.com/en-us/mats/program_install_and_uninstallI tried this and it detected no problems and so did not fix the issue.
Has anyone dealt with the same issue and have a solution?
Thanks!
Eike_Hauptmann
(To:rjeli)
Hi I think the System Administration board would be batter as this. So the customization board is all around programming stuff.
But I know that sometimes other toolkit application could crash if you have loaded the connexion driver, so you could check to startup without other Toolkit/external programmed Applications.
Br,
Eike
