Looking at your conflict picture...we have a similar issue today (3 years later...) What is PTC's solution? This Popup is very disatisfying and doesn't help out the User experience(UX).
Chris,
did you find any solution of your problem ?
Thanks in advance for any piece of information.
Martin Hanak
worth a try:
fail_ref_copy_when_missing_orig
retrieve_data_sharing_ref_parts
Reinhard
Hello
I had forgotten about this old post. At the end (quite recently actually) we were given this option
dm_auto_conflict_resolution yes
and it seems that it did the trick.
Let us know what you think
Thanks Chris,
It eliminates the pop-up window in WF5 and CP2. I'd also recommend for Admins to review the config settings for dm_check_on_the_fly and verify_on_save_by_default as the user will not get the up-front option during Open, Edit and Save actions when connected to WC.
I strongly recommend to never use this option with the users. They will not see any conflict message which are supposed to help them to solve the conflict. If there is a conflict there is a very good reason for it.
We use this option in an automatic tool which must open the drawing regardless of its condition.
My admin team has not propagated this option to our user communities. You can bet that the day we do the support team gets hundres of calls that their models got problems and they do not know why. !!!!!
The reason of that call was to find a way to make xtop.exe process more drawings per avoiding such conflict messages
Also, this option is hidden and for good reasons....
Chris,
we will use hidden dm* option on visualization machine, only.
Martin Hanak
