Sep 11, 2019 3:18 PM UTC
[1,018] Data store unknown error: [Error occurred while accessing the model provider. ?
Hi ,
When creating DataTable with service dynamically,  I sometimes get the error "[1,018] Data store unknown error: [Error occurred while accessing the model provider." .
var params = {
description: "",
thingTemplateName: "DataTable",
Resources["EntityServices"].CreateThing(params);
Things[dataTableName].SetDataShape({ name: shapeName });
//Things[dataTableName].SetProjectName({ projectName: "ABCD" });
Things[dataTableName].EnableThing();
Things[dataTableName].RestartThing();
Things[dataTableName].SetPersistenceProvider({
Resources["EntityServices"].AddShapeToThing({
name: dataTableName /* THINGNAME */,
thingShapeName: "LockableThing" /* THINGSHAPENAME */
And, if error occurs, I have the following exception handling to rollback:
 var params = {
try{
Resources["EntityServices"].DeleteThing(params);
logger.debug("Rollback data table "+dataTableName + "finished");
}catch(error2){
logger.debug("fail to rollback data table "+dataTableName + ". Error: " + error2 ); // result: INFOTABLE dataShape: "EntityReference"
var existingGhostEntities =
Resources["GhostEntitiesResource"].GetGhostEntities({
deleteGhosts: true /* BOOLEAN */
Even though,  if the error "Data store unknown error" occurs then it will always occur unless restart tomcat .  Any suggestion ?
Thingworx 8.4.2 + Postgresql 10.x
Sean
22-Sapphire I
Sep 11, 2019 3:39 PM UTC
Is this creation service execution in a set security context?
Data store unknown could be a visibility permission problem.
ie. the security context (user) that is executing the service may not have permissions to see the Persistence Provider associated with the DataTable you are creating
seanccc17-PeridotAuthor
Sep 12, 2019 2:31 AM UTC
@PaiChung ,
No,  I'm currently using Administrator to run the creation service.  It will be executed in a security context when my project go live , but for now it's only executed by Administrator.
The strange thing is that the error occurs randomly , about 1 time out of 5~20 executions.
raluca_edu
Sep 12, 2019 6:43 AM UTC
You can try to look into Tomcat logs (stderr), sometimes there is another error behind Data Store Unknown Error, and get a hint.
Raluca Edu
18-Opal
Sep 12, 2019 12:48 PM UTC
Hello Sean,
I'm sorry for not answering your question, just wondering what is your use case for creating data tables programmatically -- is that for visibility purposes?
/ Constantine
Sep 12, 2019 7:11 PM UTC
@seanccc ,
Have you looked at this Article CS239982 This article discuss how to enable a stack trace which may provide more information on what action is causing the problem.
