I tried to import through service by using csv parser but error message popped,so anyone help me to import the csv file in service. I attached the service code below
Error says that this line is the issue:
var values = Things["vaata_Data"].CreateValues();
I would just comment that out for now verify that the parse actually produces an info table.
if that is the case then i'd tackle this issue, is this the auto created snippet for DataTable entry?
