3D Model Viewer widget in Thingworx. (ThingView & CreoView)
Swapnil_More
I want to show the live sensor data integrated with 3D model in Thingworx, currently I am using 3D Model Viewer Extension from PTC Marketplace but I am not able to showcase live sensor data in Model. Is there any way to show sensor data in 3D model.
If Thingview & Creoview are able to showcase live data how can I get that widgets?
Swapnil More
Hi@Swapnil_More ,
unfortunately I could not see from this post which link you exactly mean. So supposing you want to access some link as I described in the following post (but not sure)
https://community.ptc.com/t5/Studio-Tech-Tips/How-to-use-ThingView-Widget-from-Navigate-to-display-CAD-Model/td-p/591948
Hello @Swapnil_More ,
so far I see the 3D Model view is not really related to  models of the  PTC product familiy but is a viewer based on the three.js  technology - and it does not use the  thingview libraries. This means that it could display the general formats what we can see in the metadata.xml where we can find the three laoder which are used there. So I think it is the same functionlaty shown here : https://threejs.org/examples/
I do not think that there is a direct  functionality of showing some live data but you could try to use the general three.js functionality to display some dynamic  elements (text ...)
This extension is supported by the PTC lab so for question you can contact them directly lab@ptc.com
 Another point  is that you mentioned the live data is possible in Creo View and thingview. Im really not sure if this will work. May be it could work in Creo View Toolkit but as mention there is not directly such functionality. In the Creo View toolkit the only type of markup you can create in the 3D view is leader lines.It will get expanded to others such as notes so that we can expect that this could work. As webgl iss not using plugin technology they could always render html over the top of the webgl canvas. But people would be on their own if they do that.
Hi @RolandRaytchev,
I am not able to access https://community.ptc.com/t5/ThingWorx-Developers/3D-Model-Viewer-widget-in-Thingworx-ThingView-amp-CreoView/m-p/%C2%A0https:/threejs.org/examples/
this link.
Could you please tell me that how it can be done?
Swapnil More
Hi@Swapnil_More ,
