3D model widget - controlling the sequence with JS
pporta
6-Contributor
My .pvz file contains four sequences. They are all available to me to choose from in the drop down menu in the properties of the 3D Model widget.
Screen Shot 2017-10-09 at 11.44.15.png  Screen Shot 2017-10-09 at 11.45.05.png
But...How can i select a specific one of the four sequences using scripting?
I like to control the SEQUENCE field through a choice in a list as I am working towards having a drop down list in my experience, where I can choose which sequence to show.
Anyone any good ideas?
BR
Peter
rborude
(To:pporta)
I will suggest you better go with multiple views over there you can add different sequence for the same model.
add AR view then again import the same model & select sequence like this create 4 views.
