My .pvz file contains four sequences. They are all available to me to choose from in the drop down menu in the properties of the 3D Model widget.
But...How can i select a specific one of the four sequences using scripting?
I like to control the SEQUENCE field through a choice in a list as I am working towards having a drop down list in my experience, where I can choose which sequence to show.
Anyone any good ideas?
BR
Peter
I will suggest you better go with multiple views over there you can add different sequence for the same model.
add AR view then again import the same model & select sequence like this create 4 views.
