I have a couple of questions:
1) Is there a way to add a service that will perform a "show-all" zoom function on the widget that will arrange its view to show all the points on the map?
2) Is there a way to place markers on the map that have a slightly different icon? For my case, I want to show all the sensors that are selectable on the map and then reference markers that display where the receiver stations are.
Thanks in advance!
1. There are several AutoZoom features if you check the properties of the Google Map Widget.
2. You can use State Based formatting to get different Icons to show based on a value (so you can differentiate Receiver stations that are in different states), you can also change the Marker style as well that would make them all show the same way.
Thank you!
