Able to post from browser by not via Adafruit_CC3000
sgreywilson
I have a question around connecting to my local Thingworx server
Basic setup
I have a local Thingworx server running on a desktop with exposed ip and port 80.
If I run the following below from the browser (98.XXX.XXX.XXX redacted). Which is a copy of the output from the Serial port com 7 when running the Arduino
98.XXX.XXX.XXX/Thingworx/Things/Arduino_RND_Thing/Services/Arduino_RND_Service?appKey=978d51a7-a095-482f-94d0-7ba142c9d581&method=post&x-thingworx-session=true<&humidity=20.20&temp_c=33.20&temp_f=91.76&accel_x=0.00&accel_y=0.00&accel_z=0.00>
It executes the service and updates the values shown below
If I run the same thing but use a cc3000 shield I do not see the results in the monitor
Below show the output
Attempting to update Values
server:98.XXX.XXX.XXX
appKey:978d51a7-a095-482f-94d0-7ba142c9d581
thingName:Arduino_RND_Thing
serviceName:Arduino_RND_Service
humidity=20.20
temp_c=33.20
temp_f=91.76
accel_x=0.00
accel_y=0.00
accel_z=0.00
Start Update
Just befoe client connect
connected
POST /Thingworx/Things/Arduino_RND_Thing/Services/Arduino_RND_Service?appKey=978d51a7-a095-482f-94d0-7ba142c9d581&method=post&x-thingworx-session=true<&humidity=20.20&temp_c=33.20&temp_f=91.76&accel_x=0.00&accel_y=0.00&accel_z=0.00>HTTP/1.1
Host: 98.XXX.XXX.XXX
The tomcat server never sees the post but the shield says it connected and its able to ping a server for stevegw.today but it does not get pings from server:98.XXX.XXX.XXX
I have the port 80 open but its not a domain server in that it only has an ip to connect to so I don't use getServerByName
Any ideas
Aanjan
(To:sgreywilson)
Steve, is there any other way for you to test if the shield can actually connect to your server? You could possibly run Wireshark on your server, then run the post request from the shield and capture the network activity to see what's going on.
