About Convert JSON file to Infotable
xcheung
1-Newbie
I follow the document: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS179012 to convert JSON file to Infotable, so I:
1. Create the Datashape based on the JSON key and value.
2. Create the service to getJSON file, and the code is:
var params = {
proxyScheme: undefined /* STRING */,
headers: undefined /* JSON */,
ignoreSSLErrors: true /* BOOLEAN */,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: undefined /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: undefined /* STRING */,
url:"http://servername/rest/sql/list/site/",
timeout: undefined /* NUMBER */,
proxyPort: undefined /* INTEGER */,
password: undefined /* STRING */,
domain: undefined /* STRING */,
username: undefined /* STRING */
// result: JSON
var data = Resources["ContentLoaderFunctions"].GetJSON(params);
var params = {
infoTableName: undefined /* STRING */,
dataShapeName: "TestJSON" /* DATASHAPENAME */
// result: INFOTABLE
var jsonTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
for(var i=0;i<data.length;i++)
    jsonTable.AddRow({id:data.array.id, area:data.array.area, group:data.array.group, WS_name:data.array.WS_name, state:data.array.state, child:data.array.child});
result = jsonTable;
3. After save and test, the result is an empty infotable.
Can anyone help?
liliu
8-Gravel
(To:xcheung)
Hi Mr. Cheung,
Please provide the structure of your JSON file? Do you have a arrays?
Usually, JSON content rows and use below code to convert to infotable
    jsonTable.AddRow({id:data.rows.id, area:data.rows.area, group:data.rows.group, WS_name:data.rows.WS_name, state:data.rows.state, child:data.rows.child});
If still not works, please let me know.
BR,
Lily
3 REPLIES 3
liliu
8-Gravel
(To:xcheung)
Hi Mr. Cheung,
BR,
Lily
xcheung
1-Newbie
(To:liliu)
Hi Lily,
Thank you for your kind reply.
Content of my JSON file is a bit different when using the GetJSON function. So I changed the AddRow function from ({Name:json.name })to ({Name:data.rows.name}, and then got the correct Infotable, thanks again.
XiaoYing
liliu
8-Gravel
(To:xcheung)
Hi XiaoYing,
It's my pleasure.
Lily
