Active status button
ptc-6292037
I need to have Indication of last selected button in a Pop-up.Indication could be any changed color of button or highlighting that particular button.
Scenerio: I have a Time Selection Pop-up with 10 buttons,each button for different hours.e.g. button 1 "last 2 hours",button 2 "Last 24 hours" and so on.When I select button 1,pop-up will close and data for last 2 hours will be generated on dashboards.Now again,I open Pop-up to select another button but this time,previously selected button i.e. "last 2 hours" should be indicated as last selection,either by change in color or highlights on button itself.
AdamR
(To:ptc-6292037)
For this type of selection you should use the Radio Button widget.  This allows you to define a list of available buttons and lets you bind selected text or selected value to the widget to accomplish what you need.
Right now I have Navigation buttons to be clicked,Is it possible to replace Navigation buttons with Radio buttons?
