I want to do some changes to the result which I get from calling the GetPropertyValues() on any Thing.
it will be helpful if I get the object structure it methods to manipulate the result value and extract the data which i want.
This is an infotable, so you can use a 'wrapping' service to call this information and then remove any rows you want, even rename any Property names etc.
