We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Adding a Thing to a Network
michaele
I am trying to add a Thing to a network programatically,
It is intended in this case to add a parent
var params2 = {
    to : SiteName,
    connectionType : undefined
Networks['CustomerNetwork'].AddConnection(params2);
When tested I get an error about invalid connection type....  I however can not find a resource which lists valid connection types
I seemed to have found a or the solution...   The connectionType appear to be Parent, Sibling or Child,  though I haven't yet tested all 3, At the very least Sibling works.  And I have been able to add a thing to a network in this way
paic
(To:michaele)
Actually you can leave connection type as undefined by not even declaring it in the JSON parameter block, otherwise use contains.
