Adding button inside grid, checkbox inside grid.
svisveswaraiya
Is it possible to add a button on each row in a grid which when clicked opens a popup? Also is it possible to add a checkbox on each row in a grid for multiple delete functionality?
Thanks in advance,
Shalini V.
6 REPLIES 6
On each row of a grid and advanced grid you can't add buttons with custom actions, you can add a general button on the bottom (or top) in order to open the pop up with the current selected row. For multiple delete function, you can also enable multiselect and add a button again to do the deletion, or you can use Advance Grid from the marketplace (https://marketplace.ptc.com/apps/229413/grid-advanced---version-411#!overview) which has editing capabilities and for deletion it's exactly what you are describing.
If you want to have to capacity of adding buttons and different widgets on the rows, you should use the Repeater Widget instead (on where each row it's a mashup).
slangley
(To:CarlesColl)
Hi @svisveswaraiya
If the reply from @CarlesColl answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
I have a similar doubt,
Is it possible to add dropdown in advanced grid?
Same answer as before, you need a repeater widget in order to use other widgets on rows.
Hi CarlesColl,
Thanks for your response.
After enabling the multi select, should I enable grid editing and and pass query to implement the editing and then use the delete add buttons given by default?
slangley
(To:svisveswaraiya)
Hi @svisveswaraiya
If you have found a solution to your question, please either mark the appropriate existing reply as the Accepted Solution or respond with a new solution and mark it as the Accepted Solution.
--Sharon
